IT system single phase breaking capacity
Hi
IT systems are systems conected to earth through an impedance. To lower short circuit curent, right ?
I have a situation, 380 V, 50 HZ, transformer 2MVA, where i have to choose circuit breakers for an IT system, and in CB catalog , the values for "single phase breaking capacity Iit " are very low: 6, 12, 20 kA. Or max 36 kA for "strongest" MCCBs with Icw = 150 kA for 1 s. The required "short time current" is 50KA /0,5 s.
1. Are those MCCB-s suitable, or low single phase breaking capacity makes then un-usable?
2. Aditional question: in attached diagram 10 A is the maximum short circuit current value, limited with the impedance(resistance)?
3. Then why they(engineers) ask 50kA?
RE: IT system single phase breaking capacity
So that means MCCB-s with lower single phase breaking capacity in IT systems are good? In IEC 60947-2 tests for single phase breaking capacity in IT systems are described : "A short-circuit test on the individual poles of the multi-pole circuit breaker".
I still cannot understand this: a robust CB with Icu= 150KA/1 s, in IT has the " single phase breaking capacity in IT" only 25 KA ? This means that: The CB can take 150 KA, but in IT, the same CB can take only 25, under same voltage.
Enlight me, please ...
http://w
So-in IT case , when first ph-gnd fault occures, current path is through resistor, current is < 10A. 2-nd ph-gnd fault if occurs, on a different phase, then fault current return path is not through the resistor, and current value can be up to 87% of 3p fault current, and voltage is phase to phase voltage.
Am i right that the fault current after second fault is 2p fault current?
Back to my case... if designer does not give a certain value
of maximum 2 phase short circuit current , i cannot choose the right MCCB.
