Revit Structure
5
Revit Structure
Revit Structure
Is anybody using Revit Structure?  We have a client that wants us to use it and we've been checking it out.  At first glance it looks to be very powerful.  Any opinions would be appreciated.  Thanks.
RE: Revit Structure
Our entire company is in the midst of the switch.  Using Revit Structure along with the platforms for Arch, Mech, Elec, etc.  It has it's advantages but it also has it's growing pains.  It can't really be compared to CAD and you have to get beyond the mindset of comparing it to CAD.  It's different.  Some things take much longer to accomplish than it would have with CAD, but others are more streamlined.  It's a good switch in the end, especially since BIM is the future.
RE: Revit Structure
Thanks for the response.  Those are the same points we are beginning to realize.  I myself am very excited about it, coming from the viewpoint of an engineer who also does a lot of drafting.  Thanks again.
RE: Revit Structure
We have been using Revit Structure for the last couple of jobs.  It is very powerful almost to the point of being intimidating.  We also just completed a project using Revit MEP and basically the construction documents fell out of the 3D model.  The files get pretty big.  The Revit MEP model was 28MB.  In our case we had to build the architectural model from scratch but we used Revit due to the Energy Analysis tools that links with it.  Revit (BIM) is the future of the AEC industry.
RE: Revit Structure
3
Im using it right now as a matter of fact.  My best advice is that you need to be very judicial about what projects to apply Revit.  There are a lot of "catches" that the Revit salespeople dont tell you about.  Certain building configurations will create different problems.  A lot of people are let down when they really get into the program.  It has so much potential, but has a long long way to go until its productive.  Anticipate spending many more man hours on revit projects.....most firms go overbudget with it.
All of the good structural firms out there are using Revit for basic floor plan layout, but leave all sections and details for autocad.
If you would like further information about the "catches" I could go into it.  I think there are a few other posts on this too.
RE: Revit Structure
We are also interested in using Revit with some of our projects, partly due to our interest in the program and it's integration with RISA, and partly due to requests from our clients.  We are just not sure that if it would benefit our types of projects which are mostly extremely large custom homes where we are creating a lot of custom details.  We have been researching the program and how it would link to RISA 3d for wood structures, but there is not much info on projects that are primarily wood.  Any one have any info on this?
Atomic 25, I would definitely be interested on any 'catches' that may affect how I have described utilizing Revit.
Thx!
RE: Revit Structure
I would also like to know more about the "catches".  Also, anyone know what the difference is between Revit and Tekla?
MJ
RE: Revit Structure
Catches:
#1  You need brand new computers with powerful video cards.  If your machines aren't nearly the top of the line, it will take forever to open and scroll around.
#2  Revit doesn't catch spatial conflicts automatically.  Mechanical can draw a pipe through a beam and the program will not complain.
#3  Cutting sections has huge limitations.  You create a 3d model of the framing and say cut a section through a beam to beam connection.  It will generate a section and will show a beam butting up to a beam, no connection hardware, clip angles, bolts etc.  In the section view, you have to draw the connection hardware in by hand as 2d drafting lines over the beams.  Then if later on the beam size changes, it will change the beam in your section, but the 2d drafting lines don't follow along with it.  There are probably hundreds of other section types that will cause you pain....just think about it.
#4  Drafting efficiency is just slow.  Menu setup is poor and drafting 2d lines takes longer than it does in Autocad.  The way the program is set up is for modeling, not so much drafting IMHO.
#5  Revit models are a bad choice for complex or irregular structures.  If you have anything sloped and irregular, creating models is a huge challenge because you have to know the exact coordinates where each beam goes, and you have to start making your own model pieces.  We had a custom house with a an odd roof, and our Revit "expert" took about 2 months straight just to get the basic framing geometry in the model.
#6  Line weights, section titles, section markers, etc have a different look to them that you cannot easily change.
#7  We've tried ETABS and RAM links and neither have proved reliable for typical buildings.
#8  You're going through all the work to create a 3d model in order to print 2d plans.
RE: Revit Structure
Atomic25, Now that you have pretty much convinced me not to look any further into Revit, what are some of the benefits that you have found?
Thanks!
RE: Revit Structure
I have been using Revit for about 2yrs now and I like it. I have really only used it for small industrial steel structures and their foundation and nothing else.
The initial projects with it are very painful due to the "catches" that have been mentioned.  I have termed them "pitfalls".  Sometimes it is very frustrating to do something that would be relatively simple in Autocad, but you just can't figuire out how to do it in Revit.  The help manuals definitely need improvement.
The matching of current company standards is especially frustrating and difficult to do.
However, some of the benefits that I realized are
1. Work sharing on the same model. More than one person can work on the same model in different areas of it.
2. Interference checking with existing items.
3. Rapid drawing creation and annotation once you get the "catches" of company standards worked out.
4. Changing the drawings is easy and because you change the model from which the drawings get their information, all drawings update at once.
5. Reduced RFI's because of drawings not showing the same information due to last minute changes.
6. Doing and intial 1st dump of geomotry from Revit to Risa.  They claim the link is bidirectional, but I just can't get it to work out good yet.  Most of my stuff is small, so I just update it manually.
7. Rapid communcation of concepts to others via the 3D model.
RE: Revit Structure
Revit does have some less than wonderful features, but AutoCAD does as well.  I'm an engineer and I draw all of my own stuff.  I love the 3D modeling and while the 2d drafting can be cumbersome in Revit, at least it gives you a head start by automatically displaying the beams, columns, slabs and anything else in your 3d model.  Regardless of the love / hate relationship everybody seems to have, the common consenus seems to be that Revit is the future.  I guess we might as well jump on board and get a head start.  Thanks again for all of your input.
RE: Revit Structure
I have been using AutoCAD 2004 to do 2D drafting (structural, MEP, and architectural) and I am looking into getting AutoCAD Revit MEP Suite.  I think the industry is headed to BIM so I am thinking Revit to be ready for that and AutoCAD as I transition from 2D to 3D.  (My old 2004 version causes me problems when I work with someone using Architectural Desktop 2007).  Both Revit and AutoCAD is supposed to interface with my Elite software for HVAC loads and the CAD reseller never heard of Enercalc.  I'll probaby draft structural in 2D since I never do anything large and I seem to do more MEP in the tenant improvement jobs I get involved with.
Don Phillips
http://worthingtonengineering.com
RE: Revit Structure
I find Don Phillips comments to be interesting.  Our firm has been using Autocad and Revit MEP for 2 years now.  It is so much easier to draw MEP drawings with this software.  The big debate for me as the engineer is whether to switch completely to Revit MEP or stick with both software. We use Trane Trace 700 for our load calcs but with Revit is it built right in.
As for Revit Structure, I am not convinced it will make life as productive as MEP but BIM is future.
Cvanoverbeke
RE: Revit Structure
Cvanoverbeke,
My AutoCAD Revit MEP Suite DVD's came in Friday and I hope and pray I can get a few hours within the next 30 days to try out the software.  I think Revit MEP probably works best if the architect starts with Revit Architecture to ensure the building model is accurate - especially the envelope U-values - otherwise, it means entering this information into Elite to calculate heat gain/loss.
I am looking forward to having the one-line diagrams and panel schedules automatically generated - either through AutoCAD MEP or Revit MEP.
And I have to assume the plumbing isometrics is a piece of cake.
Don Phillips
RE: Revit Structure
Don Phillips
Based on your comments it sounds like you are getting Revit MEP 2009.  Our firm has not received the upgrade DVDs yet.  If the architects you work with use Revit, then it is definetly the way to go.  Revit MEP has more features than Autocad MEP.  We just finished an industrial building with Revit MEP where we did the HVAC and plumbing, no electrical but the problem was architect did drawings in 2D Autocad.  After spending a week to building an architecural model, we were able to do the Mechanical stuff.  The big advantage for us was the IES cooling load and heat loss calcs are part of the program.  We were working with another engineer who was doing energy simulation of daylighting, process cooling etc.  We used Revit to test the IES modules.  Overall we are both pleased.
The biggest problem is learning all of the program nuances but you could say that for any software
Cvanoverbeke
RE: Revit Structure
The benefits of Revit Structure
Some objects are easier to change, such as spread footings or wall footings.  You just type in the width dimension and it redraws the foundation for you.
Some industrial applications where you have a matrix of orthogonal steel members lend themselves well to Revit.  The 3D aspects in these cases definitely make it easier to visualize what's going on.  Start throwing a bunch of skewed members in the mix, and Revit starts losing its appeal.
Worksharing is cool once you understand it and get a proper system established with your coworkers.  ie, you need to make sure you're working on different areas of the structure.  On the same note, worksharing is required in Revit since all sheets are held within a master file.
The biggest benefit is having a 3D model to "Wow" clients when they come in the office.
I honestly think the legal ramifications will limit the spread of BIM in the future but who knows...I'm sure people said the same thing about AutoCad back in the day.  Maybe steel fabricators will be less likely to sue over field issues caused by incorrectly located elements they import from Revit.
RE: Revit Structure
I'm must Revit Structure and Robot Milenium for job seeking. Does anybody have "extension 4 revit" to import/export files into robot and revit ?
To download these extensions on www.extensions4revit.com, it is obligatory to be a "Autodesk Subscriber Customer". It is imposible for a job seeker like me!
Thank you.
RE: Revit Structure
I have revit in the back of my mind but at present only use autocad Lt 2006 i.e. do mainly industrial/warehousing type work but would like to enter into 3d.  Can anyone briefly tell me if revit would have any advantages for me ?  Also how does one learn to use it and how is the learning curve for revit ?
RE: Revit Structure
The majority of my projects are for one and two story projects.  It's difficult for me to justify switching from AutoCAD 2008 to Revit just to "wow" my clients with a 3D model.  At least for now.  The software people are doing a hard sell to get everyone to buy into the BIM scenario.
For those using Revit, how much of the work is performed by an engineer instead of a CAD tech?
RE: Revit Structure
The reason to eventually switch is not for the 3D but because that is where CAD is heading.  From what I have seen, because your model is in 3D, sections and elevations are generated while creating the plan elements.  And schedules are generated as well.  If properly set up, the time to go from schematic design to construction documents should be reduced plus you can easily share models across disciplines.  I cannot wait to get a free week to install Revit MEP to see it in action.
Don Phillips
RE: Revit Structure
Thanks archeng and Don
It seems archeng that your in my sort of position.  Autocad is a great product no arguments there, but maybe revit is or will become better.  Don how much experience have you with revit ? are you still in the learning curve?  are there any good texts to learn how to use revit?  My all time favorite in learning autocad is Frey, wondering if there is such a text for revit?
Cheers!
RE: Revit Structure
We've recently purchased Revit Structure 2009 and are currently training on the program.  We've got a client who wants to use Revit on a big project and we agreed to jump on board with them.  So far, I'm very impressed.  Granted, the files are HUGE and it takes an extremely fast computer to run the program, but I love it.  Having a 3D perspective on the project makes it much easier to understand how everything fits together.  Also, I can easily dump my revit model into Etabs and ADAPT to do my design.  The learning curve is a little steep at first, but like anything, the more you use it the better you get with it.
RE: Revit Structure
I hope this isn't considered interrupting, but can somebody help me find a grid line? Revit insists I already have a grid line 7. I can't find it. I can enable the work plane, and see what plane it is on. But I can not isolate the actual grid line.
I've even saved the file under a different name and systematically deleted every thing from the model. All I can see is a work plane shaded in light blue mocking me.
I've tried the visibility graphics overrides, as well as the light bulb that reveals hidden elements.
I did receive some notices about corrupt items, along with their ID numbers, but I was told they were deleted.
Any help would be greatly appreciated.
RE: Revit Structure
Maybe you could draw a grid, select all instances and then delete.  That should get rid of it.  There are good help forums for Revit Structure here: http://www.augi.com
RE: Revit Structure
civeng80,
My experience is limited to a presentation by a vendor where he used Revit to literally design and create some simple construction documents for a single family residence in about 2 hours, plus I have been able to play with an old Revit (version 7) copy. I can see this is the future.  Once I get Revit MEP installed and put in a couple of old projects, I can see how it integrates with CHVAC (by Elite) and see if it saves some drafting time.
Don Phillips
RE: Revit Structure
Skicat
Interesting comments
So what sort of computer do you recommend for using revit? I have a pentium 4 with windows xp (waiting for new op to come before upgrading!) and 1Gbyte of ram.
Cheers!
RE: Revit Structure
Atomic25
Sounds like you know what your talking about.
I think I'll keep revit right where it is at the moment at least for the next 3 years and thats in the back of my mind.
Im quite happy with autocad.
Cheers!!
RE: Revit Structure
Our Revit operator has a P4, 3.5GB, 1 GB of ram and running windows XP.  It can hardly open the files.  We're building him a Pentium Quad Core with 4 GB of ram, dual 250 GB hard drives and running XP.  We've only got one seat of Revit for now, but eventually we'll upgrade the whole office.  It's really a small investment when you consider the amount of work we're doing now and in the future with it.
RE: Revit Structure
So you think the new computer can handle revit files?
Cheers!
RE: Revit Structure
The company that builds and services our PCs said he would be shocked if the new computer can't run revit.  Our tech will be here today using the new machine.  I'll keep you posted on his progress.
RE: Revit Structure
I would appreciate that very much !
Thanks Skicat
RE: Revit Structure
I noticed on this thread that someone compared Revit Structures to Tekla Structures.  We have recently trialled both systems and to be honest chose to go with Tekla's in the end.  Whilst we found Revit to be a good program we were frustrated with it's model size and how slow things became when we worked on complex jobs.  Also the drawing output wasn't to our standards and it seemed to take an age to try and set it up.
Tekla on the other hand was easier to use both from a picking it up perspective and a modification perspective.  The file sizes are ridiculous when compared to Revit, in the fact they are a 1/10th if not more of the file size, they are tiny.  Manipulation of drawing settings was a big thing for us as their output is ultimately our deliverable.  With Tekla it just made this process very simple.  One big winner for us was their dominance in the Fabrication market given their old X-Steel product which has now become Tekla Structures.  By using their Engineering configuration we can now start to work earlier with the Fabricator ensuring shorter project programmes and more coherant data transfer as it's the same system.
All in all i really enjoyed trialling both systems but am confident we made the right decision, especially since they release V14 today and we find that our licence now included capabilities for modelling RC so am looking forward to getting my hands on it
RE: Revit Structure
We have been using Revit for 2 yrs now, and it has proven to be indispensible esp for the big steel building structure we are doing.
The most important really is to know beforehand the clashing of members esp with services (Me , ee, etc..) and to know clearances (ceiling heights, available distances,etc..).
RE: Revit Structure
We have been in the process of evaluating Revit structure for several years now.  until the 2008 version came out, my company felt it was not ready for "prime time".  We have now been using Revit 2008 for about the last 6 months, by a small group highly trained specialists.
Our experience is very mixed.  some things are nice, but some things are so very frustrating.  Sheets of general notes are one of the most frustrating, as the text editing capabilities are very sub-par.  I do like having a 3D model to play with, especially when the architect sends his revit model.  Then I can cut sections wherever i want them, regardless if he has his sections cut yet.
Generating the model is very fast and works well most of the time.  Some geometry is a problem, as stated above.  Generating the actual production drawings is still very tedious at times, given the poor 2D drafting capabilities.
As for hardware, here are a few recommendations.  A fast processor and fast RAM are important.  Revit does not support multi-core processors, so consider this in choosing.  A faster dual core may be better than getting quad-core here.  Get as much RAM as you can.  4GB with Windows XP is recommended (well 3GB, but usually 4 is easier to install in matched pairs).  Revit does not support 64 bit operation yet, so you don't need a 64 bit system.  Get the fastest RAM you can get.
Revit is not a big hard drive user, except when opening/saving files.  But I would still get a large fast hard drive.  Running over a LAN to a central server will slow down your save/open speeds.  So if you use a server, learn about work sharing and central files.
Revit also does not require a super high end graphics card.  Revit runs much quicker on my machine than Autocad Architecture does with similarly complex 3D models.  I would look for a mid-range workstation card with 512MB ram.  I have an nVidia QuadroFX 1400 and it runs just fine, even with large 30 story models.  The exception to this would be if you want to use the new rendering engine in Revit 2009.  Then the faster graphics card the better, as the renderings, even simple ones, can take many hours.
Revit does not support dual monitors, so I would recommend one large monitor, say 24" in size or better.
Obviously, all of the things I listed above that Revit does not take advantage of, other applications you use may.  So consider those when buying.  Here is my workstation specs, and it runs beautifully with Revit 2008 and 2009.  Granted this was top of the line about 2 years ago.
Dell Precision 380
Pentium Extreme duo at 3.46 GHz
Windows XP Pro
4GB RAM
quadroFX 1400 graphics
75GB 10000 RPM SATA hard drive (runs about 1/2 full right now with Autocad ADT 2004, 2006, 2008, Revit 2008 & 2009, Staad, Etabs, ADAPT, Enercalc, mat3D, Mathcad, PCA, etc. installed)
Dell 20" LCD (24" on my wish list)
Hope this helps some.
RE: Revit Structure
For day to day useage Revit 2009 only uses one core, but when rendering Revit will use up to 4 cores.  Revit 2009 does support 64 bit, as you would have system crashes using 4 GB on a 32 bit system, ;) .  From the work I have done in Revit it has been a pain, from gen. notes to curved sloped concrete beams.
RE: Revit Structure
Well, I must disagree.  Windows XP is a 32bit environment.  I have 4GB of RAM.  I have no crashing.  None of this means that Revit supports 64bit.  Windows Xp runs just fine with 4GB of RAM installed.  By default, it only uses 3GB worth.  But if you have SP2 or later, you can activate 4GB support by enabling what is called the "3GB switch".  Do a google search for more info on this if you like.
In fact, I have personally talked to the product manager for Revit Structure (Nicholas Mangon) and asked him about a 64bit version of Revit.  He said that was not in the current development plan, but may be added for the next major release.  The current version is only 32bit.  Perhaps I should have said that there is no plan for 64bit version of Revit.  But the 32bit version should run on a 64bit system though.  My meaning was that you don't need to spend the extra to get a 64bit version just for Revit, as it won't take advantage of it.  Other apps may though, so YMMV.
And it is possible that the new rendering engine uses multi-core processors.  But basic Revit does not, and for most of us structural (or MEP) users, we are not too concerned about rendering.  But as I said, other apps may take advantage of multi-core processors.  So you need to evaluate what you are using and decide do you want dual core or quad core.  For me, using cad, revit and analysis software, none of which have multi-core support, dual is just fine.  For my computer at home, where I do a lot of photo processing using Photoshop, quad core is essential, and photoshop takes full advantage of it.
RE: Revit Structure
It seems that Revit it's self from the hardware specs above is very reliant on expensive machinery and there are mixed messages as to it's effectiveness on complex jobs.
As a new user of Tekla Structures Engineering configuration we recently got sent this http://www.tekla.com/international/solutions/building-construction/videos/FirstSteps/index.html
The link was invaluable for us to pick up snippets of information.  Also we have been working very closely with a Fabricator using Tekla recently and shaved 3 weeks of design production time as we both worked in the model at the same time, awesome for us as users.
RE: Revit Structure
Spinner666
I thought that revit was reliant on pretty expensive hardware too and mentioned this to a rep on a seminar not long ago where he disagreed. But I guess there is no one better qualified to comment than the people who use it rather than the sales reps who want to sell it.
