Dimensioning to hidden line
Is there a way in a drawing to dimension to a hidden line without having to create a section view. I am trying to show the depth of a pocket in a standard view showing hidden lines, but it will not let me smart dim to a hidden line.
RE: Dimensioning to hidden line
You will probably be informed that it is not standard practice to do that, but;
Tools > Options > System Options > Display/Selection-->Selection of hidden edges-->Allow selection of wireframe and HLV modes
cheers
Jeff, that option is for retrieving entities which have been hidden.
Quote (Help files):
Select hidden entities. When selected, you can select hidden (removed) tangent edges and edges that you have hidden manually when you pass the pointer over hidden edges.
cheers
Thanks!! That did the trick.
banghead
Do not answer posts before coffee.
Jeff Mirisola, CSWP
Certified DriveWorks AE
http://designsmarter.typepad.com/jeffs_blog
Dell M90, Core2 Duo
4GB RAM
Nvidia 3500M
Jeff,
That should be a FAQ.
Chris
SolidWorks/PDMWorks 08 2.0
AutoCAD 06/08
ctopher's home (updated 10-07-07)
Actually, there is a type of view you can use for this as still be legal with the standards.
Select your view first.  Then goto pulldown Insert>Drawing View>Break-out section.  Draw in an enclosed spline around the area you wish to break-out, and OK.
Matt Lorono
CAD Engineer/ECN Analyst
Silicon Valley, CA
Lorono's SolidWorks Resources
Co-moderator of Solidworks Yahoo! Group
and Mechnical.Engineering Yahoo! Group
