Location of vertical bracing,single storey,discussion request
Pals
In some especially colder countries, bracings are required to be placed in mid bays of longitudinal axis. This allows free expansion and contraction of  the building from mid bays outwards.
But this reduces torsional stiffness of a building terribly and wont show good performance in seismic zones for example.
What is the recommended practice and basis?
respects
IJR
RE: Location of vertical bracing,single storey,discussion request
I fail to see how this affects torsion at all. If you have 4 braces, 1 on each wall, it makes very little difference exactly where that brace is along that wall.
thanks csd72
Where will the brace matter is what I am looking for csd72, you can add more comments if you wish.
As far as I can see practice is to distribute them according to the number of bays, say 1 brace bay every 4,for example
respects
IJR
Just put them half way along each wall and then provide compression struts to bring the load from the corners.
It is the space between two brace that is the problem - effectively a shrinking beam between 2 fixed points. As long as you put your braces close together at the center then this should not be a problem.
Most buildings are heated/cooled and do not experience large temperature swings.  This seems like a non problem.
