Catia Problem
Catia Problem
1). How to create alphabets projection on surface?
2). How to create solid sweep in part design?
3). How to differential between closed surface and solid?
4). In the model tree, how to know which process is activated/deactivated? There is any key to show the current step?
5). How to create/manipulate layer function in CATIA?
RE: Catia Problem
Fernando
RE: Catia Problem
go for it, do not try to save money, you are already wasting time...
RE: Catia Problem
type text in drawing - save as dxf - open dxf - copy - past on 3d plane - project
draw one curve - draw another curve - click RIB icon
one is a surface in a geometrical set, the other is a solid in PartBody or Body
the icon next to the feature
5). There is any key to show the current step?
the feature is underlined
[i]6). How to create/manipulate layer function in CATIA?{/i}
you don't, it's really worthless in v5
READ HELP DOCUMENTS AND GET BASIC TRAINING
RE: Catia Problem
drewboy23 (Mechanical) 3 Apr 08 13:11
But problem (1), it is very INCONVENIENCE for jig/mould maker like us to engrave alphabet on the specified surface. In Pro/Engineer, we can do it much faster and convenience than Catia.
Best regards.
RE: Catia Problem
Fernando
RE: Catia Problem
That's probably your answer, right there, then... (after all, a tool maker has no need to release Catia data)
Catia Design|Catia Design News|Catia V5 blog
RE: Catia Problem
http://www.type3.com/EN/home/home_us.php
RE: Catia Problem
RE: Catia Problem
And that is exactly why your offshore competition is on this board, making Catia related inquiries.
RE: Catia Problem
RE: Catia Problem
type text in drawing - save as dxf - open dxf - copy - past on 3d plane - wrap curve
