Sorting sheets in catia draw
I have 7 sheets in a draw and their have numbers 1,2,6,4,3,5,7. Someone knows how can i order them in tree and in the up bar, without copy/paste sections, views ....?
Txs in advance.
With kind regards,
Cosirius.
RE: Sorting sheets in catia draw
That my friend depends on which Release you are on, think they added that in R16 or was it R17. Sitting right now with R18 and there you only right click on the sheet and go xxx.objects and pick reorder.
I am on 5.16 version.
With kind regards,
Cosirius.
If you don't get the option to reorder then I'm sorry to say, you are stuck on copy/paste/delete until you upgrade.
Can anybody else confirm when the reorder feature arrived?
Txs :(
With kind regards,
Cosirius.
When you say "copy/paste sections, views ...." I hope you do not copy and past view from one sheet to another...
If you select the sheet the way you want them (sheet 3, sheet 1, shhet 2) then cut, then past that should do the job...
Eric N.
