socket weld fittings (fitting allowance)
What is the min allowable pipe to fitting engagement for a socket weld?
Sftyvlv
RE: socket weld fittings (fitting allowance)
Refer ASME B16.11 Table 4.
cheers,
gr2vessels
ASME B31.1 also has information about the proper fit-up for socket welded joints.
The general idea is to leave ~1/16" inch gap at the bottom of the joint to allow for weld shrinkage.
-MJC
