Help with sketches.
Help with sketches.
I have been using NX5 for about 2 hours now because I recently started a yo-yo company and need to make a cad of the yo-yo so it can be sent to a cnc shop to get manufactured. I used diffrent software to make a 2d outline of the yoyo and am wondering if I just sketch out the 2d drawing on this if I can change the view and then make all of the parts circular. It really isn't to incredibly hard compared to some of the things I've seen that were made on this. Please answer this as quickly as possible. Thanks - James
RE: Help with sketches.
Sketch half the profile, and the centre axis then use the revolve function with the default 360 degrees to make a solid.
If you have different parts of the model shaft and two sides perhaps make each as a separate solid with individual sketches
best regards
Hudson
ht
Usually there's more than one way to skin a cat in NX. It's up to you to choose your preferred workflow.
Tim Flater
Senior Designer
Enkei America, Inc.
www.enkei.com
Some people are like slinkies....they don't really have a purpose, but they still bring a smile to your face when you push them down the stairs.
