SA-105 tensile properties - reported values question?
This may be a very silly question, I apologize in advance.
SA-105 (2007 Ed) has Tension Test requirements in the as-forged and one from each heat treat charge (if heat treated) para 7.3.1 and 7.3.2 respectively. I am reviewing CMTRs for some SA-105 and there is no real information as to what form the tensile tests were conducted. Is this ok? I would expect the mill, etc to list the values for both forms and elaborate which is the as-forged and which is heat treated/what heat treat was performed. Looking at 12.2 of SA-105 I do not see clarification as to what should be reported here on the Certified Mill Test Reports.
Your help is greatly appreciated,
RE: SA-105 tensile properties - reported values question?
Go back and re-review the MTR, carefully. If heat treatment was performed, this would be indicated on the MTR under condition. Look for normalized, normalized and tempered or quenched and tempered words in the MTR, this would indicate heat treatment condition. If no heat treatment, the tests would be indicative of as-forged material.
I guess I should have posted that as my question - if an SA-105 forging has been heat treated, shouldn't the CMTR have Tensile results for the heat treated and as-forged condition? Or is industry practice to only report the heat treated tensile results?
Thanks again,
unless specific testing was ordered
