Meshing w/ ANSYS (Classic and Workbench)
I am trying to mesh a simple cylindrical pressure vessel with flat ends. I would like to have all hex elements of type SOLID186. Is there a way that I can force Workbench to mesh the cylinder with all hex elements? I am wanting to eventually incorporate composite layers in the model. Is there a better element to use in order to do this?
Also, what is the best way to import a complex geometry into ansys and perform an analysis on it?
Thanks!
Thanks!
RE: Meshing w/ ANSYS (Classic and Workbench)
and select Hex Dominant
I've found that the easiest way to import a geometry is with the interface that ANSYS installs in your CAD software (if you have one that supports this feature)
