Converting Pro E Bills of Materials into Excel Files
I would like to convert bills of materials from Pro E files into Excel format, but I do not have the Intralink - would anyone know of another way of doing this?
Cheers
Cheers
RE: Converting Pro E Bills of Materials into Excel Files
Open in Excel, and check the box "fields seperated by commas" or something similar. Un-check the "seperated by tabs" box.
I've done this a few times, and I'm sure if you play around with it, you'll find what I'm talking about,
David
From an assembly file, pick 'Info/Bill of Materials.' Pro/e will ask you to set a few options and will then create your BOM.
then if you have the 'info_output_format' config option set to text, you'll see a new text file in your working dir with a text output of your complete bom.
you can also format the bom any way you wish by setting the 'bom_format' config option and editing the file that it points to.
another way
http://inv
but you need to
http://www.proefaq.com/?page_id=199
score.. I'd like to know more about the .fmt file
You can see it here:
http://i
Marc Mettes
Inversion Consulting
http://inversionconsulting.blogspot.com
