UDF Wizard in NX4
UDF Wizard in NX4
Hello All
I may have posted this before, but has anybody else had problems with the UDF wizard? Basically, we are running TCEng and NX4.0.4.2 and when we try and use the UDF wizard, it fails instantly giving us and error which says "ERROR OCCURED WHILST BUILDING WIZARD DIALOG" However, it works fine in native. Any help in overcoming this problem will be greatly appreciated as it's causing me great pain an suffering due to the constant ear bashing I'm getting from disgruntled engineers. (No joy from Siemens either as yet)
Best regards
Simon.
Best regards
Simon.
RE: UDF Wizard in NX4
Another cause could be that you simply don't have the system resources to run both Tc and NX.
Thanks anyway though.
Simon
Have you checked your syslog? There may be some usefull information there.....
Obviously you have plenty of computing power.
UGII_UDF_IMAN_TOP_LEVEL_FOLDER /Home/Company_Folder/Standard_Parts/UDFs
UGII_UDF_IMAN_WITH_NATIVE_DATABASE no
the path may not be the same for you. This is where UG will create the UDF files in TC.
Make sure you have permissions to create files in here and the relevant folder exists.
The second just uses the files in the folder structure in TC to create the list instead of the old fanggled text file. If this is set to "yes" and no file exists this could cause a problem. I'd suggest making it "no".
That seems to work for us.
Mark Benson
Aerodynamic Model Designer
