First steps to customize Solid Edge?
To anyone how would like to help,
By changing my job, I find myself working with Solid Edge.
There seems to be much less documentation available to customize it.
(I use to work with Solid Works)
I stumbled upon the site off Tushar Suradkar.
But his eBook seems a little out of date. (Version 14)
Is there anyone with some tips where to start?
René
René
RE: First steps to customize Solid Edge?
Change the button size on toolbars (tools, options, helpers)
Turn on sketch relationship colours
Turn on 'indicate under-constrained profiles' in Edge bar
Correctly set up the File Locations to point to common files
Ensure the dimension style mapping in draft is turned on.
Set up the intelli-sketch options.
Turn on the 'maintain relationships' in 2D model space.
If I think of any else I'll let you know, sometimes I think these should be on as default...
KENAT, probably the least qualified checker you'll ever meet...
What customization am I looking for?
Well, the problem is that I need to be more flexible within our projects, then programs like X-steel can deliver.
(Parameter based drawing programs)
But I need to be faster then possible with a modeller like SE to bring my work into production.
Thanks to "HDS" I found a good batch printer.
(Jason Newell) That's a start.
Batch changing part-properties would be very helpful,
for instance.
René
Hope it helps
Patrick
René
