400 bar leak-free thread
Hello all,
I am currently developing a solenoid actuator which has to fit onto a vessel; Vessel is about 1 liter volume and is filled with air/nitrogen at max 400 bar pressure. Maximum temperature is about 100°C. The fitting between actuator and vessel is about 14-18 mm diameter. Obviously the fitting must be leak-free. I am looking for a threaded fitting for installation pourposes. Any suggestion about a preferable solution for the thread?
thanx
thanx
RE: 400 bar leak-free thread
trust this helps.
