channel design
channel design
channel design
if your using a channel to support a load how do you check the channel against buckling/bearing of the web?
RE: channel design
Same as an I-beam.
RE: channel design
cheers, have already realised. Just assumed it was more complicated!!!!!! Thanks.
RE: channel design
So channels and HSS are the same as I-beams, but not angles, correct?
RE: channel design
The spread of the load in a HSS is a little different due to the external curvature. An angle doesnt have a bottom flange, so is completely different.
RE: channel design
CSD:
Not to be cute, but if the angle is upside down, it has a bottom flange.  This happens all the time in marine construction where angles are used, upside down as it were, to stiffen the underside of deck plating.
I know...picky, picky, picky.
Mike McCann
MMC Engineering
