Fillet weld preheat
Fillet weld preheat
Fillet weld preheat
We have an AWS qualified CS(P1 to P1)WPS,without preheat.
We have 40 to 50 mm CS base material that requires 10mm fillet welds on 2 sides. Required preheat for this thickness
is per Table 3.2, 150F / 65C. Can I use the qualified AWS WPS (without preheat)to weld these fillets, preheating as required for the thickness, or must I qualify another WPS
with the required preheat.
RE: Fillet weld preheat
Preheat can always be increased from the minimum that was qualified. I would preheat according to Table 3.2, and use the AWS qualified procedure.
Preheat isn't typically WPS-dependent, if nothing else because the plate thickness on your WPS may not be the same thickness as your piece.
Hg
Eng-Tips policies:  FAQ731-376: Eng-Tips.com Forum Policies
