caterpillar diesel generator
Can anybody please help with some information about 400kVA Caterpillar Diesel generator with Perkins motor and ECM Perkins Governor.
I didn't find this information in the technical manual and unfortunately the respons of the distributor here(Eneria) is not as should be.
I want to know the value and connection of potentiometer for analogue speed regulation. There are inputs for digital and analogue speed regulation but it is no indication about value and connection of potentiometer for analogue regulation(there are inputs for analogue control, analogue ground and +5V supply).
Thank you!
Pafi
Thank you!
Pafi
RE: caterpillar diesel generator
Type: GEP400-2_I
Thanks!
Pafi
If you have a serial number I may be able to help find some info.
