How to summarize resource utilization by month
I have a VB script and I am trying to determine which variables I can use to produce the following matrix
resource name X YYYY-MMM (and report effort + cost).
I can extract from task the following
duration
start and finish time
I can then extract the resources per task
with this I can extract the resource name, rate, peak units
the resource cost I get is for the entire project and not the task.
what I am unable to figure out is how to extract by day/month the resource utilization.
this is a subsection of the code, that I have been trying to see what information I could use to get the extract I need
Sheets("TEMP").Select
Range("A2").Select
ActiveProject.Activate
hours_Per_Day = ActiveProject.HoursPerDay
Dim t As Task
Dim ts As tasks
Dim A As Assignment
Set ts = ActiveProject.tasks
For Each t In ts
If Not t Is Nothing Then
' For Each A In t.Assignments
'change the following line to use
'for a different custom field
'rid = A.ResourceID
start_date = t.Start
end_date = t.Finish
num_resources = 0
task_name = t.Name
duration = t.duration
task_cost = t.Cost
For j = 1 To t.Resources.Count
ActiveCell.Offset(0, 0) = task_name
ActiveCell.Offset(0, 1) = start_date
ActiveCell.Offset(0, 2) = end_date
ActiveCell.Offset(0, 3) = t.Resources(j).PeakUnits
ActiveCell.Offset(0, 5) = duration / 60 / hours_Per_Day
ActiveCell.Offset(0, 6) = t.Resources(j).Name
ActiveCell.Offset(0, 7) = t.Resources(j).Cost
ActiveCell.Offset(0, 8) = t.Resources(j).Number5
ActiveCell.Offset(0, 9) = t.Resources(j).Code
ActiveCell.Offset(0, 10) = t.Resources(j).StandardRate
summ_row = summ_row + 1
Range("A" & summ_row).Select
Next
End If
Next t
duration
Range("A2").Select
Dim t As Task
Dim ts As tasks
Dim A As Assignment
For Each t In ts
'rid = A.ResourceID
end_date = t.Finish
num_resources = 0
task_name = t.Name
task_cost = t.Cost
Next
End If
Next t
