Trim end of pipe
Trim end of pipe
Trim end of pipe
I am trying to master some piping features (2007 sp5)
From my tool box > structural steel I bring in a piece of pipe and extrude it. Then I bring in another size and position it so it becomes an offset Tee.
How can I trim the excess that protrudes into my original pipe if I start from the center plane? If I start from an exterior plane and project "up to body" or "up to next" I am left without a hole.
I can think of a number of round about ways or possibly making the whole thing without importing structural steel.. but there must be a "proper" way to accomplish this.
Thank you for your time
Ralph
RE: Trim end of pipe
Have you tried using the Weldment function? This would handle the trimming easily; the hole, if needed, would have to be added manually.
cheers
Thanks for the response.. I quickly tried the weldment function.. with little sucess sad
I can accomplish what I need by using the "offset entities" setting the offset to a small value and then extruded cut. Messy but working...
Thanks for that link.. I had no idea that SolidWorks tutorials were available on youtube.. Very nice
This is getting better and better... Thank you
But now... I notice that the selection of choices available from Insert > Weldments > Structural Members is a lot less than the choice from Toolbox > Structural Steel.
Is this a function of some file location problems that I have overlooked? Can the libraries be combined?
Thanks again
In Task Pane > Design Library > SolidWorks Content > Weldments; there are downloads for many other profiles.
cheers
