Does anyone have experience with the use of chemical demolition agents
I am rehabilitating a steel bridge and the concrete end diaphragm has embedded steel bracing utilized during original erection. I am redecking the bridge and reconfiguring the abutment/diaphragm. I need to remove and replace/reconfigure the concrete of the end diaphragm without damaging the steel bracing.
Does anyone have experience with the use of soundless chemical demolition agents (SCDAs)?
VOD
VOD
RE: Does anyone have experience with the use of chemical demolition agents
http://mmwaterjet.com/hydro.htm
http://demolitiontechnologies.com/
http://www.nonex.com/
VOD
Mike McCann
MMC Engineering
Mike McCann
MMC Engineering
If you look at this website it talks about Bristar being taken off the American market and replaced by Bustar.
