Need liquid coating for exterior metal application
Looking for a coating for a project. Coating needs to be highly UV resistant, easy to apply on large metal surfaces-preferably a spray application, the coating needs to create a friction less barrier between the metal and outside elements as in rain, snow, ice, etc
Thank you
Thank you
RE: Need liquid coating for exterior metal application
http://www.densona.com/DensoLiquidCoatings.htm
Hello.
Another company to consider is Wearlon: http://www.wearlon.com. Their products are self-applied, UV stable, air-dry, formulated for release (non stick).
You see, it's release you really need, not lubrication. For an explanation of the difference, see
<a href="http://w
Good luck!
William Gunnar
http://www.IndustrialCoatingsWorld.com
