Painted into corner by millimeters
I'm working in multi-unit assemblies, inch and mm parts.  Assembly is in Inch.  Need to wave link geometry into a mm part, but cannot set it as the work part.
Whats the work around?
RE: Painted into corner by millimeters
Make a new higher level assy with the units set to millimeters, then assemble the whole mixed-units assy into it.
Of course, now you will not be able to make any part with units other than millimeters the work part.
