Selection of Contactors for Star Delta Starter.
Could someone please help me out with the current rating selection for star-, delta- and main contactor for a star-delta starter?
durgeav
durgeav
RE: Selection of Contactors for Star Delta Starter.
Keith Cress
The 2 main contactors can be sized at 58% of the motor current, the star (shorting) contactor can be 33%. But some manufacturers will require you to use identically sized contactors even for the Star because their mechanical interlock mechanism may not work on disparate sizes.
I would suggest using the HP ratings of the contactors rather than the ampacity ratings. I would use full HP rating for the running contactor. I would consider rating the starting and shorting contactor based on the reduced HP on the star connection.
Bill
"Why not the best?"
Jimmy Carter
LOL
LOL
Hey I didn't even notice. And to be honest I sometimes spell it wrong myself. Left to themselves everyone will miss spell it because "i before e except after c" (or k!!!)
Keith Cress
If I want to size the contactors for a 10 kW, 415V,50 Hz 3-phase squirrel cage motor, according to Waross I'll be sizing the delta and main contactors @ 58% of the motor rating. This means the delta and main contactors shall be rated for {10,000/(1.732x415x0.8)}x .58 = 10 A and star contactor shall be sized for 17.4 A x 0.33= 5.7A.
Waross,
Have I understood it right?
Please also note that the ambient temperature is 45 deg C.
What are the other factors that I have to consider for the sizing of the contactors?
Also, it is always best to use motor nameplate FLA rather than calculated FLA if at all possible. Not all motors are created equal.
Great treatise on the subject:
http://www.lmphotonics.com/m_start.htm#StarDelta
http://www.lmphotonics.com/star_delta.htm
For a 10kW motor is a Y/D starter worth the trouble? An 11kW motor stared DOL is within the capacity of most industrial supplies, even in small premises. If the supply is weak enough to warrant reduced voltage starting then the solid state soft starter mentioned earlier is likely to be more effective in preventing disturbance to the supply.
The overload relays ( 03 ) must be connected in each branch of the motor winding. (six leads brought out)
The adjustment selected for 0.577 motor full load current.
This gives the motor full overload protection on the starting and running steps.
For motor duty use the motor HP ratings on the contactors.
For non-motor duty use the ampacity ratings on the contactor.
Bill
"Why not the best?"
Jimmy Carter
Definitively yes.
OLR (3 ph type)to be connected after 1M contactor.
Contactor 2M simply complete the delta connection.
OLR adjustment: 0.577 motor full load current.
Please see "Magnetic Control of Industrial Motors"-page 64
Gerhart W. Heumann/ John Wiley & Sons
