Extruded cut up to surface revolve - not the expected results
I recall this coming up in a previous post but I cannot find the thread. I am trying to cut a profile from a solid and using a surface revolve as the termination for the cut. SW allows me to select the surface but when the cut is made it is to an another point in the model.
Apparently it is not possible to make a cut this way or I am missing something. The post I recall reading had said this was possible in SW08. Suggestions?
Harold
SW2008 SP3.0 OPW2008 SP0.1 Win XP Pro 2002 SP2
Dell 690, Xeon 5160 @3.00GHz, 3.25GB RAM
nVidia Quadro FX4600
www.lumenflow.com
RE: Extruded cut up to surface revolve - not the expected results
The curve is a parabolic if that matters.
Harold
www.lumenflow.com
Harold
www.lumenflow.com
However, I did a quick test and the Cut up to surface works for me. See attached.
Thanks again CBL.
Harold
www.lumenflow.com
Seems like the other route should have worked but not so.
Harold
www.lumenflow.com
