Working with layers
Working with layers
When i click on the icon for a note, weld symbol etc how can i change that to a specific layer before i create the object? I prefer to do it before the object is created to avoid the forgetten few. Thanks
RE: Working with layers
OR if you created the annotation already,
In the PropertyManager pane that comes up when you click on an annotation, simple pick the layer within the layer section.
Matt Lorono
CAD Engineer/ECN Analyst
Silicon Valley, CA
Lorono's SolidWorks Resources
Co-moderator of Solidworks Yahoo! Group
and Mechnical.Engineering Yahoo! Group
If you look at Handleman's post, you can add "swWeldSymbol" or other annotation types to the macro to include them also:
http:/
Flores
1) Current drawing template has a layer for balloons, so i need to ensure these go were they are required.
2) Changed color of text in titleblock. Which of course is all notes and wants to put on note layer.
If i can solve those issues bingo i am there. However i think that they might be kinda difficult, but at least i have a start.
Ultimatly i would like this to be more of a hidden process such as;
User wants to insert a balloon into drawing. So he clicks on "Balloon Icon" (Macro in disguise sets layer to Balloon). Insert balloon and off to next action.
Vision would be to have all these "Icons" in a custom company standard type toolbar.
All in all i feel i am on the right track and any help given is help greatly appreciated. Thanks
Edit sheet> pick text > on "Line Format" toolbar pick the "Line Color" tool > uncheck the "Default" checkbox and pick the color you want.
You can pick several notes on the titleblock at a time and de-select the "default" checkbox.
Save the drawing as a template and sheet format and you will not have to repeat those steps again.
Flores
I see that if i record a macro of making a note with a specified border that when i view the macro i see some code
boolstatus = Note.SetBalloon(1, 0) whereas the 1 represents the type of border selected.
Would it be possible that from within your macro that if i were to search for notes that had certain border criteria i could put them on specific layers?
