Concrete Pier Design
I am looking for a good example on how to design a square concrete pier on a isolated square/rectangular footing. The loading would consist of a vertical and horizontal load (typical metal building loading). I am unsure how to analyze the pier due to the horizontal load. Do I treat it as a cantilever beam? Since there is typically reinforcing on all four faces, do you treat it as just a square beam with reinforcing on one side? Thanks...
RE: Concrete Pier Design
