Extend surface menu greyed out
I have a model with a lofted surface, I want to extend the surface to lengthen it but the Extend surface icon on the toolbar is greyed out. Any help is appreciated
tom
tom
Tom Malinski
http://www.okayind.com/
Dell Prec 670, Xeon 3.8,2GB Ram, Nvidia Quadra FX 3450/4000 SDI
SWorks Pro & PDMWorks 2007 SP3.0
RE: Extend surface menu greyed out
I am assuming that a simple square sketch when extruded then has 6 sides / surfaces that should be able to surface extend. Is that correct?
Tom Malinski
Thanks for listening.
Tom Malinski
Another way to switch your solid feature to a surface is to use the Delete Face option on the Surface toolbar. This will allow you to remove one or more of the 6 faces and make the rest into surfaces.
Michael
