Proctor Test on Shales
One of our labs is attempting to perform a standard proctor test on a highly weathered shale material from central PA. Although the material is clearly above optimum moisture, the density is continuing to increase (even after dropping slightly on one point). Has anyone had this experience? Any ideas why this is occuring and what can be done to correct?
RE: Proctor Test on Shales
