Steady-State Thermal Analysis to Transient
Hello;
I would like to have your help to solve a problem in ansys.
I already having my template in ansys it is a 2d a problem of an heat exchange, with a change of phase material, which is applied in cavities. In the inside of the heat exchange I have de R134 the inside the flat tube and arround I have de phase change material and everything contained in an aluminum where it is applied a convection. I wish to know, which the elements types that I should  use and, after obtaining the steady-state solution how can use this solution to establish the initial conditions for a transient thermal analysis.
Help is greatly appreciated.
