A way to use a driven dimension in an expression?
SE seems not to let us do this, although its really handy.
Is there a way to cheat it?
RE: A way to use a driven dimension in an expression?
Hi Arlenn,
I don't quite follow what you mean here.
Are you talking about drafts or models ?
Can you give an example ?
bc
I've come across this and the answer is if a dimension is driven, then its value can be derived from other the other dimensions...
M
