Convert Entites
Convert Entites
Convert Entites
How do you convert all entites of a surface when in a sketch? When I select a surface which has inner and outer edges the only the outer edges are converted.
RE: Convert Entites
You can convert an inner contour by slecting a face and an edge of a contour.
