Structural member / type --> not all types?
Hello everybody,
why I cannot see in the type list all types of profiles when I use "Structural member"? For example, if I use "Structural steel" from Toolbox I can choose in ISO/SC Beam between SC100, SC120... but in "Structural member", I select Standard = Iso but under Type is only "angle iron", "c channel",..., "sb beam", but no "sc beam" (which I really need)! Is this just a matter of settings (options)?
Thanks in advance.
Conrad
RE: Structural member / type --> not all types?
In the task pane, go to your design library->Toolbox->ANSI Inch->Structural Members. There should be a couple of zipped folders in there that contain what you want.
I believe that's where they're located. I unzipped mine some time ago and don't remember their exact location...
Jeff Mirisola, CSWP
Certified DriveWorks AE
http://designsmarter.typepad.com/jeffs_blog
Dell M90, Core2 Duo
4GB RAM
Nvidia 3500M
