Pack and Go
Pack and Go
Pack and Go
Trying to copy a large assm. to another directory and rename. I am tryignt to use the pack and go feature and bring all the drawings with each sub-assm. It seems to be bringing only the .drw file the main and not the subs.??
RE: Pack and Go
I typically do not pack n go the assemblies, I pack n go the drawing to make sure everything is included.   On the pack n go screen, are you checking the "Include Drawings" checkbox?
Flores
RE: Pack and Go
I've had similar failures w/ P-n-G.  It's just not finding the drawings, even if they are in the same folder as the models.  Sometimes worky, sometimes no-worky.  Quirky.
RE: Pack and Go
Exactly Tick. I do have the box checked to include drawings. I got it to work on one assm and not the next. I was hoping it was just something that I was missing.
RE: Pack and Go
"It seems to be bringing only the .drw file the main and not the subs.??"
Did you mean the main drawing (.slddrw) document and not the sub-assy models or sub-assy drawings?
Are you using multi-sheet drawings?
cheers
RE: Pack and Go
It brings all the part files with it and all in the correct sub folders, but it does not bring any of the drws. from sub folder A, B, C, etc. I only get the main drw. Yes to the multi sheet.
RE: Pack and Go
Like smcadman, I usually use the TL assy drawing as the Pack and Go selection and only remember having problems when PnG was first introduced.
cheers
RE: Pack and Go
Let me give you a better example of what I'm trying to do. I am taking an existing job, that is very similar to my new job, and copying. I need to open the main file, and all of it's subs. What I need to happen is when I update, change, modify my new design, for the drws. to update accordingly. Keep in mind, the job is 100% detail. Which is why I need all the sub drws. Thanks
RE: Pack and Go
I have a top level assembly model c/w sub-assembly models.
I have part models.
I have a multi-sheet drawings for each of the above.
In SW Explorer, I select the top level assembly drawing and do the Pack and Go on it. I make sure that the Include drawings option is selected, and that all relevant parts are selected. I rename documents using the Select / Replace option, specify the destination folder and hit save ... and everything works the way it should.
cheers
