Tolerances Not Showing On Drawing
Hi All-
I'm working with WF2. I'm trying to show tolerances in the drawing; however, they're not showing up. Is there a config.pro option that could cause this to happen? I'm working with an older config that I didn't make. When I click on the properties of a dimension, I cannot change the Tolerance mode from (As Is) to plusminussym, plusminus, etc. The tol_mode option is not in effect in my config.pro.
Any help would be appreciated. If any more info is necessary, please let me know.
Thanks for you help.
V
RE: Tolerances Not Showing On Drawing
Nevermind!
I had tol_display to yes, but only in the model. Whoever set up the drawing format overrode it in the drawing setup to no.
Thanks to all who thought about answering this question.
V
