German Standard Equivalent for Machining
Hi Guys ,
I got a Print from Germany for two parts to be made for local mfg. co.,the standard they use for this particular part is DIN 7168, Is there any Perfect Equivalent for this Standard
RE: German Standard Equivalent for Machining
I believe that is an old standard and has now been replaced by ISO 2768, not sure if that actually helps you any.
Confirm ajack1's info - use ISO 2768-1 and -2.
Cory
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips Fora.
Amazing what google will turn up:
http://www.me.metu.edu.tr/me307/Standards/tolerances/DIN7168.pdf
I believe the others are correct that the is replaces the DIN but...
If the DIN is specified on the drawing it may be more correct to use that, although they're broadly equivalent.
http://www.techstreet.com/cgi-bin/detail?product_id=1677
You can get partial extracts of the ISO for free online too, such as: http://www.ramo.se/iso_2768_english.htm
However, I had a lot of trouble when dealing with this spec, the German vendors interpretation of certain aspects didn't mesh with my interpretation (or that of the US rep for the German Company).
thread1103-196260: Tolerance analysis ISO2768 thread1103-197786: tolerance analysis to ISO 8015 & 2768 part 1 (again!)
Also if you get hold of the ISO spec, which you probably should, take a long hard look at the last section.
KENAT, probably the least qualified checker you'll ever meet...
