From excel to Catia
From excel to Catia
I want know if there is a way to generate a excel tabel into a draw, but here is the tricky thing, i want catia to write automaticlly what is in the 3d tree.
In other words when you have a assembly design and you have numbers assigned to each part i want catia to generate a tabel with the componence of the tree. Something like bill material.
With kind regards,
Cosirius.
RE: From excel to Catia
Save as txt file, you will have the whole tree exactly like in CATIA.
Fernando
any ideas? I want to do this via a macro...
thanx for your help
regards,
luis
or you can make a script.
the txt is sepparated by tabs to make columns...
