close footings
close footings
In order to check the effect of two footings close to each other I used Stuart, J.G. (1962) paper "Interference between foundations with special reference to surface footings in sand.’’ Geotechnique, 12(1),15–23.The same method is described in Das's book.
My question is how to estimate the distance in each case (Stuart has 4 cases)?
RE: close footings
Jeff
