VBA Code Debug
VBA Code Debug
VBA Code Debug
So it's probably obvious that I am a newbie by looking at my code. Why doesn't this work? What should I do to fix?
In this example I use the Excel Formula in C3 =CountA(Sheet2!A:A), which returns the value of 11 (number of rows not empty), which includes Headers.
I want to copy the Range on Sheet2 (A2:F11) because the count told me 11 rows to Sheet1 (A2:F11)
Dim MyCount = Integer
Dim i = Integer
Sub do_it()
    MyCount = Sheets("Sheet1").Cells(C, 3)
    For i = 2 To MyCount
        Sheets("Sheet1").Cells(A, i) = Sheets("Sheet2").Cells(A, i)
        Sheets("Sheet1").Cells(B, i) = Sheets("Sheet2").Cells(B, i)
        Sheets("Sheet1").Cells(C, i) = Sheets("Sheet2").Cells(C, i)
        Sheets("Sheet1").Cells(D, i) = Sheets("Sheet2").Cells(D, i)
        Sheets("Sheet1").Cells(E, i) = Sheets("Sheet2").Cells(E, i)
        Sheets("Sheet1").Cells(F, i) = Sheets("Sheet2").Cells(F, i)
    Next i
End Sub
RE: VBA Code Debug
When referring to cell "A1" using the .Cells property, you should use Cells(1,1), not Cells(A,1).  Also, with .Cells, the row number comes first.  So cell "C2" is Cells(2, 3).
-handleman, CSWP (The new, easy test)
RE: VBA Code Debug
try
sheets("sheet1").range("A2:F11").value = sheets("sheet2").range("A2:F11").value
RE: VBA Code Debug
Thank you for your help. Both of your solutions helped point be in the right direction. I was missing one critical component to the MyCount variable.
MyCount = Sheets("Sheet1").Cells(C, 3).value
the MyCount varialbe was not getting the value of cell C3 so the loop was never functional. Here is the code that solved my problem.
Dim i As Integer
Dim MyCount As Integer
Sub do_it()
    MyCount = Cells(1, 3).Value
        Sheets("Sheet1").Cells(i, 1) = Sheets("Sheet2").Cells(i, 1)
        Sheets("Sheet1").Cells(i, 2) = Sheets("Sheet2").Cells(i, 2)
        Sheets("Sheet1").Cells(i, 3) = Sheets("Sheet2").Cells(i, 3)
        Sheets("Sheet1").Cells(i, 4) = Sheets("Sheet2").Cells(i, 4)
        Sheets("Sheet1").Cells(i, 5) = Sheets("Sheet2").Cells(i, 5)
        Sheets("Sheet1").Cells(i, 6) = Sheets("Sheet2").Cells(i, 6)
    Next i
End Sub
Thanks again.
