Supressing an annotation with an expression.
I am making a lot of parts using the family parts function in NX4. I want to have the drawing in the part update along with each family member. For one family set, I have a bolt circle, which is controled with a suppression expression, "1" turns bolt circle on, "0" supresses it. I have an annotation in the drawing which calls out the bolt circle, hole diameter, etc., and I can not find a way to supress the annotation automaticly when the bolt holes are supressed. So when I supress the bolt circle, the callout still appears, but with no associativity.
Any help would be appreciated,
Rick
Tool Engineer
Rick
Tool Engineer
RE: Supressing an annotation with an expression.
In drafting u can select Edit->Suppress drafting object.
In the dialog select Expression button, and select whatever expression u want, and then select the annotation, dimension, or centerlines etc that should be suppressed (or unsuppressed) by this expression.
For example here u can associate bolt circle expression to this annotation.
