Untolerance dimensions
Hi I have a question about notes;
It is valid to use this text:
UNLESS OTHERWISE SPECIFIED:
DISMENSIONS ARE IN INCHES
UNTOLERANCED DIMENSIONS ARE BASIC
(aditionally I am including a feature control frame defining a profile surface tolerance for them)
RE: Untolerance dimensions
First half is more or less ASME Y14.5m-1994 1.5.3: UNLESS OTHERWISE SPECIFIED, ALL DIMENSIONS ARE IN INCHES.
Second half is similar to 5.2.11 (b): UNTOLERANCED DIMENSIONS LOCATING TRUE POSITION ARE BASIC.
So I would suggest you adjust your wording to more closely follow the standard, however, the basic idea is OK.
My preference is to indicate basic dimensions with the box around them per 3.3.4 & fig 3-7 but that is just my preference, the note about untoleranced dimensions does comply with the standard.
KENAT, probably the least qualified checker you'll ever meet...
