Slip Type Expansion Joint Modelling
I wanted to model some ATS slip type expansion joints. I used to make two runs: the first for the actual displacement and the second to include the axial stiffness. Is the still the proper technique?
RE: Slip Type Expansion Joint Modelling
Refer to Caesar II documentation for modelling techniques. Don't forget pressure end effects.
