Open API, problem with plot
I'm new of the forum and NXOpen/C#, I'm try to write a command utility to plot in pdf a UGS/NX3 drawing, but I hit some problems and due to my poor experience I'm not able to fix it.
My first attempt was to create a CGM to PDF converter, but I realize is not possible to do.
So the second attempt was open a .prt drawing then convert in pdf, but here I got 2 problem
1) I was unable to do Plot.SaveCgm due to this error:
Unhandled Exception: NXOpen.NXException: NX error status: 1105012
at NXOpen.UF.UFPlot.SaveCgm(Tag drawing_sheet, JobOptions& job_options, String job_name, BannerOptions& banner_options, String cgm_file_name)
at cgm2jpg.CGM2IMAGEConverter..ctor(String[] args) in D:\User Profiles\apelle\My Documents\Visual Studio 2005\Projects\cgm2jpg\cgm2jpg\CGM2IMAGECon
verter.cs:line 88
at cgm2jpg.CGM2IMAGEConverter.Main(String[] args) in D:\User Profiles\apelle\My Documents\Visual Studio 2005\Projects\cgm2jpg\cgm2jpg\CGM2IMAGEConv
erter.cs:line 115
2) I use as pre-condition and existing CGM file and then try to print to file with: Plot.PrintFile, no error seems to be riese but no output will write. Here the log of NXPlot
26 Mar, 2008 14:16:17:BPS: SUBMIT_TIME
26 Mar, 2008 14:16:17:BPS: Job 0 Submitted
26 Mar, 2008 14:16:17:BPS: Sending bSec ...
26 Mar, 2008 14:16:17:BPS: Sending bPrintTo ...
26 Mar, 2008 14:16:17:BPS: Sending myModel ...
26 Mar, 2008 14:16:17:BPS: Sending myPlotter ...
26 Mar, 2008 14:16:17:BPS: Sending myProfile ...
26 Mar, 2008 14:16:17:BPS: Sending C:\Temp\3455603_ug_drw.cgm ...
26 Mar, 2008 14:16:17:BPS: QUEUE_TIME
26 Mar, 2008 14:16:17:BPS: Job Ready to Run
26 Mar, 2008 14:16:17:BPS: RUN_TIME
Wed Mar 26 14:16:17 2008
BPSPLOT: 1.0012 Windows NT 4.0COMMAND_LINE :"apelle" "PDFPlotter" "myProfile" "3455603_ug_drw.cgm":
Input FILE - 3455603_ug_drw.cgm (PASS)
Bypass Lic B ---------------------------- B -sdil329736934
Connect Method: CONNECT_EXECUTE
Queue_Name: ()
CMD_EXE: ( "3455603_ug_drw.cgm")
Exec Return A 0 226 Mar, 2008 14:16:17:BPS: DONE_TIME
APPENDING STATS FILE
END OF STATS FILE
26 Mar, 2008 14:16:21:BPS: Downloading logfile.txt ...
Thanks in advance for you support.
Alfredo
My Code:
using System;
using System.Collections.Generic;
using System.Text;
using NXOpen;
using NXOpen.UF;
using System.Runtime.InteropServices;
using NXOpen.Drawings;
namespace cgm2jpg
class CGM2IMAGEConverter
static Session m_session;
static Random r = new Random();
static UFSession m_openSession;
public CGM2IMAGEConverter(string[] args)
m_session = Session.GetSession();
m_openSession = UFSession.GetUFSession();
System.Console.WriteLine("m_session :" + m_session.ToString());
if (m_session == null)
System.Console.WriteLine("m_session NULLA");
else
System.Console.WriteLine("m_session NON NULLA");
System.Console.WriteLine("m_openSession :" + m_openSession.ToString());
if (m_openSession == null)
System.Console.WriteLine("m_openSession NULLA");
else
System.Console.WriteLine("m_openSession NON NULLA");
PartLoadStatus pls;
Part p = m_session.Parts.Open("c:\\temp\\3459923_ug_drw.prt", out pls);
DrawingSheet[] dss = p.DrawingSheets.ToArray();
Console.WriteLine("Sheet number: " + dss.Length);
int i = 1;
foreach (DrawingSheet dw in dss)
Console.WriteLine(i++ + ": Altezza: " + dw.Height + " Larghezza: " + dw.Length);
UFPlot.JobOptions jo = new UFPlot.JobOptions();
jo.use_drawing_sheet_colors = false;
jo.use_drawing_sheet_widths = true;
jo.tolerance = 1;
jo.colors = UFPlot.Colors.BlackOnWhite;
NXOpen.UF.UFPlot.BannerOptions bo = new UFPlot.BannerOptions();
bo.show_banner = false;
bo.message = "";
jo.widths = UFPlot.Widths.StandardWidths;
// Console.WriteLine("1 " + dw.Tag);
// Console.WriteLine("2 " + jo);
// Console.WriteLine("3 " + bo);
m_openSession.Plot.SetSessionBannerOptions(ref bo);
m_openSession.Plot.SetSessionJobOptions(ref jo);
int seed = r.Next(1000000000);
string fn_pdf = "C:\\temp\\filename_" + seed + ".pdf";
string fn_cgm = "C:\\temp\\filename_" + seed + ".cgm";
Console.WriteLine(fn_pdf);
Console.WriteLine(fn_cgm);
//m_openSession.Plot.SaveCgm(dw.Tag, ref jo, "To_Cgm: " + fn_cgm, ref bo, fn_cgm);
m_openSession.Plot.PrintFile("C:\\Temp\\3455603_ug_drw.cgm", "PDFPlotter", "ps_profile_0", 1);
//m_openSession.Plot.ConvertFile("c:\\temp\\3455603_ug_drw.cgm", UFPlot.Format.TiffFormat, "c:\\temp\\out.tiff");
//m_openSession.Plot.Print(dw.Tag, ref jo, "TIFF Export File 1", ref bo, "TIFF Export File", "DRETIFF", 1);
public static void Main(string[] args)
CGM2IMAGEConverter convert = new CGM2IMAGEConverter(args);
verter.cs:line 88
erter.cs:line 115
Queue_Name: ()
END OF STATS FILE
Alfredo
My Code:
using System;
using System.Text;
using NXOpen;
using NXOpen.UF;
namespace cgm2jpg
else
else
PartLoadStatus pls;
int i = 1;
jo.tolerance = 1;
bo.message = "";
RE: Open API, problem with plot
