Display Problem
Display Problem
Display Problem
when I rotate a medium assembly, it turns to block shapes instead of keeping it original form until I syop rotating.Could anyone tell me where the setting is to turn that off. I want to zoom in and out and see what it looks like at all times.
RE: Display Problem
Tools > Options > System Options > Performance ... adjust the Level of detail slider bar to suit.
cheers
RE: Display Problem
Also check the number of components setting in Tools > Options > System Options > Assemblies.
cheers
RE: Display Problem
It will also behave that way if software OpenGL is enabled.
Eric
RE: Display Problem
Thanks for all the help. I got it to work
RE: Display Problem
For others with the same problem ... what was the fix?
cheers
RE: Display Problem
Turn it OFF.
