Hole Note Problems
Hole Note Problems
Has anyone had any luck getting the hole note to call out threads per an ansi standard?
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: Hole Note Problems
Our shop got confused by the way a tapped hole is drawn by the wizard, so I put in a hole for the tap drill and add a cosmetic thread with the text I want to see.
I also edit the data files for the holes to simplify the text entry in the feature tree.
Crashj 'busy busy' Johnson
