re-associate dtf file to parent par file?
If a change name is required of the parent par file to the child dtf, is there a way to re-associate the drawing to the model?
re-associate dtf file to parent par file?re-associate dtf file to parent par file?(OP)
Red Flag SubmittedThank you for helping keep Eng-Tips Forums free from inappropriate posts. Reply To This ThreadPosting in the Eng-Tips forums is a member-only feature.Click Here to join Eng-Tips and talk with other members! |
ResourcesWhat is rapid injection molding? For engineers working with tight product design timelines, rapid injection molding can be a critical tool for prototyping and testing functional models. Download Now
The world has changed considerably since the 1980s, when CAD first started displacing drafting tables. Download Now
Prototyping has always been a critical part of product development. Download Now
As the cloud is increasingly adopted for product development, questions remain as to just how cloud software tools compare to on-premise solutions. Download Now
RE: re-associate dtf file to parent par file?
Don't forget that if the part is used in an assembly you will have to change the link there also. Either with Revision Manager or using the Replace command in the assembly.
The best way is to get to know Revision Manager, then you can rename,copy and replace files and still maintain all the links.
bc
KENAT, probably the least qualified checker you'll ever meet...
At the same time all files were renamed to have the new project number in the filename.
It's a real 'sweaty palm' time when you finally hit the button to start the process !!
After that it's Property Manager to change all the file properties to change part numbers etc.
bc.
In a dft file this morning, I wanted to replace a .psm file for an .asm file (because the part changed and is now made of 2 separate sheetmetal parts), but it didn't even allow me to select a file type different from the original one.
I was able to replace it in the asm environment though.
