Solid Edge internal FEA
I was fooling about with the internal SE FEA.  However every time i go to apply a constraint to my part, it seems to upset the just applied force, and will not let me continue without redefining the force, which in turn is upset again by the application of the constraints.  Any help?
"edits to the model have removed some or all load or constraint geometry. edit the loads or constraints and run the analysis again."
Thanks in advance
RE: Solid Edge internal FEA
just a guess. Are you putting them on the same features?
I know you have to ask such questions from time to time, but no, im not.
I will post a screen shot when i get a few minutes.
