Fastener for rotating sheet metal joint
I am working on a design that requires a rotating joint between two shhet metal parts.  Ideally, I would use a shouldered rivet, but the client needs removeable fasteners.
Are there any commercially available fasteners specifically for sheet metal joints that must rotate?
RE: Fastener for rotating sheet metal joint
Not a bad ooption for some cases.  Our larger cases would require diameters at least .312"
