Scale Issue - Xrefs
Scale Issue - Xrefs
Scale Issue - Xrefs
Greetings,
I was working on a drawing with multiple Xrefs and now when I plot the file, all of a sudden there's 200 more scales that I can use that has the "_Xref" suffix attached to it.  Then if I remove the Xrefs from the .dwg file the scales remain. It doesn't hinder my drafting however I am still curious why the scales remain after I remove xrefs. I tried copying my model into a new drawing but the scales come with it.
Thanks in Advance,
Keith
RE: Scale Issue - Xrefs
It's the latest built-in AutoCAD virus :)
Use "scalelistedit" to remove the extraneous ones (by selecting "default").  Unfortunately this has to be done in every drawing affected.
Here's a discussion on some lisp code to help clean up the mess-
http://discussion.autodesk.com/thread.jspa?threadID=648918
