Coil Field Examiner.
I would like to setup a coil field examiner to test the strength of magnetic fields from metal detector coils.
First up
Is there a difference between AC & DC magnetic field detection equipment?
What is the best cost effective method to do this simply, is there a simple circuit i can use to get the field strength to a data acquision card in a PC.
RE: Coil Field Examiner.
Detecting an AC field is easy. You just use a small coil of wire. The smaller the coil the less the induced voltage but the better the spatial resolution. You will be using Faraday's Law of Induction.
E= N * d(phi)/dt
N turns.
phi is the total magnetic flux through the coil
d(phi)/dt is the calculus expression for the rate of change of magnetic flux.
phi = flux density * area of coil
None of this works for a DC field. For a DC field you need either a Hall effect device of a GMR (Giant Magneto Resistive) device.
Hopefully these points can be googled to get you more data.
Cheapo version of gaussmeter for detecting dc fields:
http://my.execpc.com/~rhoadley/magmeter.htm
As was mentioned, to detect ac what you need is a coil connected to a high impedance voltmeter (draws virtually no current).
V = d/dt (Phi) = d/dt (N*A*B(t)*cos(theta)
where N is number of turns, A is area, B is flux, theta is angle of coil plane compared to flux... we will from this point forward assume the coil is tilted until max measurement -> cos(theta)=1
V = N*A*d/dt(B)
Assuming B (and hence V) are a single frequency sinusoid with B and V representing peak values,  at frequency f, then Vrms = V/sqrt(2) and ||d/dt(B)|| = ||2*Pi*f* B||
Vrms = N * A * 2 * Pi * f * B / sqrt(2)
Vrms = Pi*sqrt(2) * N * A * f * B
Vrms = 4.44 * N * A * f * B
B= Vrms/(4.44 * N * A * f)
Everything in SI units. Else add appropriate unit conversions.
Maybe it goes without saying, but.... the sense coil has no iron. Otherwise it changes what it's trying to measure (flux density in air).
