weld bead length tolerance
Friends,
Question about weld bead lengths when explictly called out on a print.
On a drawing we have utilizing an 1/8" fillet weld, which joins two pieces of 1/8" Aluminum extrusion we also require the length of the bead to be 1/2". What does AWS or any other standard state about the length tolerance of the bead? I was looking through some AWS standards and couldn't find anything.
Mike
Mike
RE: weld bead length tolerance
Definition of tolerances of any dimension is a design engineering function, and as such must be done by the design engineer.
What is the minimum length that will provide the necessary strength?
-Mike
Chris
SolidWorks/PDMWorks 08 2.0
AutoCAD 06/08
ctopher's home (updated 10-07-07)
